Preventing water damage in utility room
RogerS
20 Feb 2004
In the eternally wet North
Just had the floor retiled in the utiiity room as part of a refurb. The floor level had to be built up slightly to bring it in line with the kitchen floor and I used plywood sheets for that duly screwed and stuck down. My tiler mentioned that it would be a good idea to seal around the perimeter to guard against any water ingress from leaks getting into and blowing the plywood.
I was going to try and find some sort of waterproof flowing compound that i could carefully pour into the gaps but then had a better idea. Namely to put silicon on the bottom and back of the skirting boards when they are applied. A sort of mini-tanking if you get my drift.
Can anyone see anything wrong with that approach?
Roger, Are you putting down a wooden skirting?
Personally I try and avoid silicon as much as possible. I reckon it always discolours with age and never looks right.
If the floor is tiled could you use a skirting tile? Glued and grouted would would make a very good seal. As you have a tiled floor I guess you will be cleaning it with water, which over time, may discolour wooden skirting
I am not suggesting that silicon would not make a good seal but for me tiled floors should have a tiled skirting. This also means you can slop water around to your hearts content when washing the floor.
Andy
Cheers, Mark.
Andy - it will be wooden skirting - probably painted - walls are way too much out of whack to put tiles on and I dont think that Chief Designer is that fond of tiles on walls!
If not tiling an upstand, then I would use an MS Polymer rather than silicone, more expensive up front, but then the sealing bond should last 20 years rather than 5 or so.
Get a good quality white (other colours are available) bathroom sealant - if its good enough for showers on a daily basis it will be good enough for the occasional floor wash once or twice a week.
Steve
It's not how well it seals while it is sealing, it is how long it remains bonded at all. Silicone has a limited life expectancy and this is not going to be easy to replace.
