Ross K
What I mean is that when you glue up (let's say with PVA - I use Titebond III most of the time), how do you remove any excess that squeezes out?
I tend to avoid putting too much on in the first place so that I get only a tiny line of beads squeezed out, then remove it very carefully when hard using a dog-leg/canted neck chisel.
I've always tried to avoid using a damp cloth as it tends to spread it around and then it shows up when you oil/Osmo.
Peeling the glue off with a chisel when it's only gum-hard is sometimes easier but not always possible.
I was in the workshop today gluing up an oak piece and I got too much glue on. As an experiment, for the first time in ages, I used a damp cloth to remove excess while it was still wet. I may regret it but it may save me time ultimately and it got me thinking how you guys and gals remove your excess glue.
Saying "I always put on the right amount" is not a viable answer!! :wink:
