First off this is not on the level of you guys, far from it but I thought I would just share with you my latest tinkering in my workshop build. Basically using what I had to hand , out of scrap. Our wedding anniversary was Sunday and as it is Steel, I bought my wife this hand forged rose which is very nice indeed and she loved it. It is designed to be in the garden and rust over time but no way was that going in the garden.
So had to think of a way to mount it but it is quite heavy so the stand would have been large to carry the weight but I thought it would be too bulky and tip over. So looking around the house I found an old Ikea desk lamp which luckily has a weighted base.
So came up with a cunning plan. Which involved demolishing the lamp for its base ! That was easy enough ..
So ended up with the parts I really needed. The metal base with slot, the cast iron weight and a plastic cover.
Then fettled the rose with a hammer to follow the bend of the groove into the base and drilled /tapped the stem so I could secure it .
Now the fun part, making a base out of some scrap CLS timber I had lying around. This proved to be quite challenging as I had to router out a recess the depth and size of the base so it could fit in underneath and also work out how to reveal the slot.
Took a little bit of head scratching , a huge mess and not exactly a perfect circle as no way of using a router jig as the radius was too tight but you will never see my terrible hand routing anyway :)
Finally you end up with this. All components ready to go back once I have put a finish on it.
Heavy base installed
And the end result .. I think she will like it , if not will give it to the mistress :)
I can hear the call where has my desk lamp gone....!🤣🤣🤣
It is my old desk lamp that was about to be chucked in the loft so no great loss and anyway as the saying going " what is mine is mine, and what is yours is mine " so she benefits from me keeping stuff just in case......
I haven't tried yet but have considered it, only difficulty I have is my lathes slowest speed is 450 so it would spray everything around me unless I build a box around the turning.
Some people have hocked up an old bbq rotisserie motor for applying finishes, and epoxy finishes. I wonder if it would be too slow for wet sanding?
Jigsaw table for a friend of mine. She has MS and can’t get about much so spends a lot of time sitting down. I hope this will give her something to occupy the time.
My daughter is gifted with textiles and making clothes and my hobbies are woodwork and metalwork so we’ve started collaborating. Hence the logo.
    144.4 KB
    106.7 KB
    108.3 KB
    111.3 KB
    103.6 KB
    98 KB
    124.6 KB
    189 KB
    210.7 KB
I’ve actually made two items. I attended an Axminster demonstration by Helen Baily of thin wall bowls and decided to make one. I needed a pre-settable caliper to ‘feel’ the wall thickness and see from the setting screw how much needed to be removed, so I designed and produced this one. (If anyone is interested in obtaining one, please drop me an email at [email protected]). I then used it to produce this Tulip Wood bowl, whose wall thickness is 2mm.
    75.9 KB
I just finished these. Still need to shoot some shellac on them. My wife liked the first one I made her so much she keeps me busy making them for gifts. I'm burning out on this pattern fairly fast. I hope you like them. About 15 hours in each one. A John Nelson pattern from the book Boxes Bowls and Baskets.
What did you use to cut them?
Fantastic! What an amazing thing to do.
I had to resurrect the old Black and Decker DN85 belt sander, but needed a rectangular to round adapter to connect my Dyson to the sander.
A
and 3 hours of 3D printing.
Perfect fit!!
Can you tell me what printer you have? I’m looking to get one. To do just what you have done. I need an adapter to the bottom of my unisaw for a dust port.
An ingenious devise and a beautiful bowl 😁
I got a Monoprice mini delta V2 (Malyan M300) as a Christmas present. It has been one of the best 'toys' I have ever had I use it all the time. First, disadvantages:- It's print bed is 110mm Diameter X 120mm high, so relatively small when compared to some of the bigger units out there. So far, it hasn't really been a great problem for me. It doesn't do really small parts very well, but I suspect that's a common problem for all 3D printers.
The good points. It's cheap. It works very well, self leveling bed, the supplied slicer, Wibuilder works very well, it's very quiet, It works out of the box, WiFi connection. There's a good support site here.
I'm sure I will get a larger printer in future, but I would still use the Monoprice.
I use FreeCad. So far, I've been able to do everything I need using it.
