Ahh, the last one I made,admittedly, the only one I've made was a mortice gauge, approximately 16" long, in rosewood.
I gifted it to my college, wish I'd actually kept it now.
They have to be the simplest, but most useful tool we have and utterly invaluable.
Good day
I'm sharing with you my little project - a silencer box for an air compressor.
Design premise - cheap and functional, relatively small. Will only run for a minute max (don't worry about overheating), to fill a pressure pot. It will live in the house tucked under a work desk.
If not obvious from the pictures, I've starter with the base, where I placed the labirynt for the air intake. Used a carpet off cuts I had available. Once fully closed off, I've placed the springs somewhat evenly to support a plate for the actual compressor. Then I glued the box sides on, finished with the top board to have a complete cube. Cube was then split in two halfs, and I have doubled the walls in the base, to A. provide thicker barrier for the sound, and B. to act as a guide to fit the lid over the box. For supply of electricity, I've just bought an extention lead, switch and a grommet. For the air hose, this was 600mm whip and quickfit connector, which I epoxy glued in place. Last steps was internal padding, and there I called it finished, and ready for use.
How was the result? I don't want to blow my own trumpet, but it was better then I was hoping for. without the box and compressor running, you would have to shout quite hard to be able to communicate. With the box, it's just a quiet talk, as you would like it. You know it's running, but you don't really care that much about it running.
What do you guys thing? Not pretty by any means, but works a treat.
    193.7 KB
    114.2 KB
    148.1 KB
    62.5 KB
    115.2 KB
    141.6 KB
    86.8 KB
    143.9 KB
    165.5 KB
    148.3 KB
Good day
That's a nice job. I boxed my vertical tank compressor up about three years ago. I can hear myself think now. Although it does have a small labyrinth air intake, I can take the front of the cabinet off if ever I was to use it with something like a paint sprayer, which is twice in the time I've had it. And, as for looks, your cabinet is a piece of fine furniture compared to mine.
The good thing about lockdown is having time to finish off those jobs around the house which never got finished, I started this cabinet in the downstairs cloakroom before I had kids, my eldest son is now 11yrs old, where does time go 😲
The oak top is finished with external varnish, I have tried a few different oils and none have stood up to the water/soap splashed everywhere. The under counter bowl looks nice but is a totally impractical design.
The curved front if flexible MDF, not sure if it shows in the photo but you can see the ribs of the MDF in places, I always use ply for things like this these days.
Not fully finished yet as a bit of tiling needed, probably leave that for another 12 years.
My first go at making a box of any description, I made this for my wife, I have lined it with pig skin sued, and used craft resin for the lettering, oh and reclaimed oak inlays and top, its not perfect but it is for me
    126.5 KB
    183.3 KB
    170.8 KB
Good job. At first I thought you had put 2 screws through top but they are knots!
