Hello, I`m new to this forum and reasonably new to wood turning.
Also I`m no engineer, but believe I can understand basic mechanical problems, but just now I`m baffled !
Apologies for the long description, but it might avoid lots of questions if I go a bit into detail.
A couple of years ago I bought an old Poolewood 28-40 Superlathe, the mechanical variable speed version. From photos I`ve seen on the forum I believe mine has been altered or is not the standard set-up.
The ones I`ve seen have one wide belt which drives the shaft directly from the motor. However, as you can hopefully see in the photo, mine has three belts, one of which has been replaced with a "link" one.
I have used the lathe a lot over the last two years, and over the last month it got continually louder. I had heard of others having this problem before, but the only comments I read were that that seemingly happens with age.
Today while sanding the outside of a bowl the noise suddenly disappeared, and it went really quiet (nearly like a modern lathe ). At first I thought some problem had solved itself, but not so. Shortly after, a different noise appeared, but only when I put pressure on the sandpaper / bowl.
So I stopped the lathe and had a look inside. It appeared that all three belts didn`t feel tight at all.
The speed of the lathe should only be changed when the lathe is running, and I don`t think I accidentally ignored this. But even if, I can`t see how all belts would be slack.
There are four shafts over which the belts run. Let`s call the furthest away one A, the next, motor driven one B, the next one with the two pulley wheels C and the final head stock shaft D.
Shaft A and D are absolutely fixed and can`t be adjusted or moved.
Shaft B is attached directly to the motor, and can be adjusted by moving the motor back or forwards. The three bolts holding the motor were/are absolutely tight, and I`m 100% confident that the motor hasn`t moved. Also the motor is fixed in the position of nearly full stretch to the belt, but the belt is extremely slack.
Shaft C is the only movable one, which changes position when the speed wheel is turned.
So I could understand if the two belts running over shaft C were slack if I had made some mistake with the speed wheel , but the belt between shaft A and B is by far the slackest ! It`s a toothed belt, and I can easily move it about between the different "tooth marks" on the wheel. It doesn`t look damaged at all, just as if it was too long, which it obviously can`t be, as the lathe has worked perfectly until now.
As I said, I`m baffled, but there`s probably (hopefully !) an easy explanation and solution for this...
Especially as I need to finish three commissions before the end of the week !
If anyone could help with advice that would be much appreciated !!!
Many thanks,
Ansgar
Many thanks,
Ansgar
