Polishing glass edges
Grahamshed
14 Apr 2012
Oxfordish
Hi all
I have cut up some old glass doors to make smaller ones. Anyone know how to polish the edges so I don't slice my fingers off ?
Despite urban myth, glass is not super hard (*). SiC or Alox, either in whetstone or sheet abrasive form, will work it easily.
BugBear
(for example, "testing" a diamond by seeing if it will scratch glass is a recipe for buying a lot of quartz...)
BugBear
So an Alox disc on a ROS would suffice ?
Presumably you only want to take off the sharp edges, I wouldn't use an ROS, it could set up too much vibration and shatter the glass especially when working on the edges, rather some wet & dry and a piece of wood and rub along the edge, not across it.
Andy
Have always used a lubricated carborundum stone, just to take off the really sharp corners. +1 for not using any powered sander, too big a danger of terminal vibration and also fine dust.
very timely, this. Just had a 250mm square, 3mm glass, 8mm bevel made (for a display box) - and I had exactly the same question. I would not let them grind the edges as I could not work with the rounded effect. I was guessing a finer diamond plate... about to give it a go (wet of course). I can imagine wet'n'dry would be fine too, as BB says, glass (normal) is actually quite soft.
