Please can someone shed some light on this before I go insane!
Wiring up some cctv cameras using POE. All cameras work when using pre-fabricated cat5e cables. The camera LEDs light up inside, but they won't actually work. Its definitely my home-made cables that are the issue, but for the life of me I can't see why!
Anyway...
I've got a tester and measured the pre-fab cables against my own. They're identical in every aspect according to the tester (photo attached).
Now, I was under the impression that it doesn't matter what order you crimp the 8 wires into the RJ45, so long as they're identical at the other end (which mine were according to the tester).
I've just had another go (after about a dozen unsuccessful cables) and for some reason when I use the correct order of colours (orange+white /orange / green+white /blue /blue+white /green/ brown+white /brown) it works.
Have I just crimped better than my previous efforts, or is there an actual reason why this works but using my own order of colours wouldn't? The only thing I could think of is electronic signal loss because certain colours run closer to others in the wire.
I don't understand what difference the colour sequence makes so long as each wire is in the same order at each end of the cable?
Any guidance gratefully received!
Anyway...
