lined mine with 18mm green grade flooring chipboard. Very hard surface to this so great for fixing things to. I mounted them end up and they slotted together so no joins as such. I found this the cheapest 18mm man made board.
MattRoberts":61w11gkd said:I've just recently clad my shop in 18mm osb, mounted on 20mm battens. I painted it white (one coat of cheap emulsion). I'm very happy with it - 18mm is thick enough to take a screw and hold a decent amount of weight. The white paint helps with the light a huge amount.
One thing I wish I'd done though, is put some insulation behind it. If I didn't care about the cost and I cared about the look, I'd go for plywood, but only the cheap stuff - zero point in getting anything more expensive if you're going to paint it. Crappy void ridden 18mm ply takes a screw just as well as baltic birch
No issues with fire/building regs doing this?decas":2zht944n said:I built a garden studio a few years ago and lined it with 18mm spruce ply. The ply came from B&Q on a trade account with an extra discount for 10+ sheets. Reasonable price, easy to work, very pleased with the result. Ply was applied over a good amount of insulation. Given 2 coats of trade emulsion it has stood about 6 years of use very well. The sheets were fixed with stainless screws and the edges joined with dry fitted dominoes to keep them tidy without having to cut the boards to match the joins to the fixing battens. If I were to do it again I would use 12mm softwood ply but it was not readily available then.
Dave
Moonsafari69":wslcy5cn said:Has anyone had need of following building regs (given size of building or proximity to boundary)?
Guess this is your point Bodgers?
Moonsafari69":2gre8oaq said:Suddenly, and maybe unnecessarily a tad fire paranoid... damnit
I also have a detached garage that’ll soon be a new workshop. Have you installed dry lining on yours then? How has that panned out?
Dominoes for alignment - good idea.decas":1na2xim6 said:Softwood ply has a rough/textured surface which was fine for the studio and would I think be fine for a workshop. Accurate and straight edges align very well with the dominoes. Wipe decorators caulk into any cracks/splits/gaps.
Take the point about fire risk but there is always something that will burn. Have a couple of extinguishers installed.
Dave
Moonsafari69":2q5w2srk said:Has anyone had need of following building regs (given size of building or proximity to boundary)?
I like the look of OSB. I like how it looks with a clear finish on it, painted with a washy coat so it's coloured but you can still see the wood, and painted solid white so you're left with an interesting variegated texture.Fitzroy":34ierjln said:Osb is ugly, painful to paint well, and still ugly afterwards.
