Mrs C
Hi
Can I pick some brains? The next project is to make quite a number of storage cabinets (hallway, kitchen etc.) where the carcasses will be good quality 3/4" ply for sides and base, with something thinner on the backs. I will be using a domino for the joints.
1) I am going to need more clamps and want an excuse to by some Besseys. Can I overclamp a domino joint? Can I get away with the uniclamps or should I go for the Revo? Also, I believe that you can join two Besseys to make a longer clamp, how effective is this? Any other makes worth considering?
2) Regarding finishing, I was contemplating spraying the insides of the units before I assemble them. Any reason not to do this? I am assuming that I will need to tape off the bits that will be glued? Also, any thoughts as to the best varnish like stuff to use that can be sprayed easily? I dont mind the ply looking like ply, but it will need to be sealed properly so that the insides can be wiped clean.
Sorry, lots of questions but any words of wisdom gratefully appreciated
Many thanks
Many thanks
