toolsntat
Yep, I collect tools and tat
Is there a reason I shouldn't cut this 28mm pipe to give access for ply shelving sides (the bottom was hard enough!) and then reinstate with a straight compression fitting?
As far as I'm aware it is a drain off pipe from a Tundish and a pressure relief valve.
It should be said that the sides cannot be lifted over due to ceiling height.
Cheers Andy
Cheers Andy
