Hello,
I am working on a "special" project which is a cover board for a TV-R wall socket to obscure the cable going from the wall socket to the floor as my son & partners always try to pull the cable out of the wall. I needed to make a groove for a satellite cable into the cover board. I had an ingenuous idea to use the Record 044 plough plane, which I had bought earlier this year, instead of chiseling the groove like a mortice.
If the plough plane is a roughing tool, I did great. However, if it is a precision tool, I have a lot to improve. I have even watched a lone youtube video of Paul Sellers on how to set up and use a plough plane.
Here is a random picture of the plane from the internet.
For my project, I have used 9/16 cutter, as this one is the biggest I have.
I have a few questions:
1. Should the side screw that secures the iron push it to the side or go underneath the iron? There is so little area on the screw head that can push the iron to the skate, that it twists and lifts the iron up (unless the top screw is secured first). Paul Sellers secured first the side screw, so I did the same.
2. Paul Sellers told in his video that the iron should protrude a bit over the skate, otherwise it will not work. However, there is no gap to let the iron protrude by moving it to the side. I can only skew the iron.
I can only do this when the side screw is undone. When I tighten the side screw, the iron straighten ups and no longer protrudes the face of the skate.
3. The top screw touches the iron very close to the edge of the side of the iron (not near the center of the iron). When I skew the iron to protrude the skate, the top screw only touches the iron at the very edge of the iron, or even just partially, which is rather flimsy.
Can you please advice what is the correct procedure for setting up the plough plane regarding the questions above?
Maybe it would be better to create an auxiliary wooden fence, as the plane was pushing itself out of the cut and the groove was wider than the cutter with various marks on the sides, that I had to clean up with the chisel.
Or maybe I should save up for something like this
Thank you for your answers.
