please help
pauly123
New member
17 Jun 2009
hi i have been making rabbit hutches out of 6mm ply and i have created toeplates which are very accurate when it is time to cut out templates there never very accurate i'm using a table top saw but then having to file edges of the cut outs so they match each other i ae the sides of the hutch is there a better or easier process which will cut these out precise instead of a few mm out like what is happening all the time it is realy slowing me down thankyou in advance paul uk
Calpol":1te9rxyg said:
Use a router with a bearing cutter :D
sorry to sound stupid but would i need a router table to do this and is there a guide on it for acuracy thanks
No you don't need a table, the bit has a bearing at one end which is the same diameter as the cutter
Can you please use capitalisation and punctuation? Reading that made me out of breath!
BugBear
BugBear
Agreed...good job it's not in the competition 'cos I wouldn't even bother reading it - Rob
