Many months ago (year? ) I had a bandsaw that gave indifferent accuracy results. After researching my problems on this and other sites, reading all I could on bandsaw set up, I bought 2things. I bought Steves workshop essentials on setting up a bandsaw, and I spoke to Ian at tuffsaw and bought some new blades. My 14 inch SIP now cuts easily with a very fine degree of accuracy that I would not have thought possible from a bandsaw. It is very likely that many bandsaws do drift and introduce inaccuracies into the cut, but it is wholly wrong to think that as its only a bandsaw it has to be that way. I have a reasonable aftermarket adjustable fence fitted to my saw. The adjustment is used to make the fence true to the slots, not to the drifting blade. The drift is tuned out of the blade to make it cut true to the slots. Don't put up with blade drift and think it has to be that way. It doesn't. It can be made to cut very true if you follow the procedures that Steve covers in the workshop essentials DVDs.
This is essentially the same as when you set up a table saw. It would be silly to set the rip fence to be parallel to the blade and ignore the slots! Sure you could rip accurately, but cross cutting or any cut involving the table slots would be inaccurate. In both cases the slots are the key, and the blade and fence are adjusted to agree with the direction of the slot.
Before I set up my bandsaw I was attending a show somewhere, Yandles I think. I looked at some xtremely well executed segmented turnings, as this is where my major interest is. The 80 - 90 year chap that had produced these exhibition pieces cut his segments on a bandsaw! I have tried many methods of cutting segments, and my preferred method is to use a two fence sled on my table saw. I had not considered using a bandsaw for this task because I thought that bandsaws lacked the repeatable accuracy required for this exacting task. I came away from there with confused thoughts after looking at this chaps superbly cut segments. That was the trigger to research bandsaw set up. Buy Steves DVDs and follow the set up process and you will be amazed at what is possible. I still cut my segments on a table saw. I've made an investment in it and it performs well. i do however use my bandsaw for many more cuts than I used to do when I thought of it as an inaccurate machine, including cutting veneers for building feature rings for my segmented turning.
