Waka,
Right, now we're talking. For fun I'll do a IIWM rating too (If It Was Me). Naturally all just my opinion, all secondhand options have been ignored for simplicity and I'm interested to see what everyone else suggests. Crumbs, we might even get a consensus of opinion! :shock:
Saws. Yep, I sorta reckoned it was probably the L-N ones.
They are nice (Charley, amongst others, can vouch for them), but having held one in my hot little hands I'm now a confirmed
Adria saw fan. Anyone who's willing to give a 1yr guarantee on a saw gets my vote anyway, but that brass back milled from the solid... Mmmmmmm.
But when all's said and done it comes down to comfort to decide between the two makes. I liked the Adria but I have small hands and IIRC some people have reported problems with larger mitts. My best advice is, if you can, try before you buy. Unless you want your tools to match, in which case the L-Ns may have it... :lol: What about sharpening though? Even the best saw in the world doesn't stay sharp forever.
As regards curves I was thinking of fretsaws, coping saws and bowsaws. Not that I can really recommend any particular one of the first two, except I've had better luck with an
adjustable piercing saw than I have with coping saws for removing the waste in dovetailing (fwiw). If you fancy a bowsaw then making
your own (or
here) is good fun. IIWM - Set of small Adrias and an adjustable piercing saw.
Planes. For reference, the rule of thumb is low angle for end grain/cross grain and high angle for knarly, reversing, difficult and downright bolshie grain. As with all rules, there will be exceptions.
Jointer; easy peasy. Any #7 you like. The L-N is very nice, but then so's the Clifton. Even any old Stanley can make for a good jointer in my opinion
unless you see yourself using it alot as an uber smoother, in which case tolerances vis-avis sole flatness etc may become an issue. IIWM - Clifton #7
Smoother; you've not specified it, but I'm assuming...? L-N #4 1/2 without hesitation, possibly with a high-angle frog in the long term. Unless you want to combine your smoothing with a low angle ideal for end grain, in which case the L-N #62 or #164 depending on which you feel comfortable with and some extra blades to provide the higher angle grinds. IIWM - L-N #4 1/2 with a spare blade with a back bevel.
End grain; low angle block plane. The one plane even the most Normite-minded tends to end up with. Again the L-N with adjustable mouth is suggested every time, but... <gasp> it's the one L-N I really don't like. :shock: I find it too heavy for its width making holding it difficult. Probably not an issue for 99.9% of woodworkers (there's always one, and I'm it :roll: ), but might be worth trying first if you can. I like the bronze block better, but for a spec-similar alternative there's the Veritas. If I could only
see one, I could give a definite IIWM for it, but I'll take the risk anyway.
Rebate plane; something you haven't listed, but it's so useful to have at least one plane that has a blade across the whole width of the sole (ooops, where did that slope come from...). Again, a blind recommendation for the Veritas shoulder plane IIWM, although Tony (I think?) speaks highly of the L-N rebate block. You could combine the last two catergories into that one plane of course...
Spokeshave; Chris can give the lowdown on the L-Ns, but for my money I'd start with the Veritas low angle (there's that name again - I should be getting commission for this!). You'll almost certainly end up with a wide range of shaves from which to choose anyway (DAMHIKT), and this is a friendly one to get started with.
Give lots of thought to how you're going to keep everything sharp; it's easily the factor that makes the most difference in using hand tools. Without getting that okay all the L-Ns in the world are just so many annoying lumps of metal. Well all right - nice to look at lumps of metal... :lol:
I'll have to stop now 'cos my four typing fingers are in danger of dropping off. :wink: Feel free to ask for clarification on anything; it may be too brief on some points 'cos I was trying to keep it short... honest.
Cheers, Alf
