Manufacturers fault. It's probably a late product when the trade and quality control was dropping off. What sort is it?
NB fairly easy to straighten if you stick to paper-backed 80 grit wet n dry and use it wet on a very flat, rigid, impermeable surface. I use the bed on my planer. There's an obsession with flattening/polishing, which takes hours, but is usually completely unnecessary
PS no need to go beyond 80 grit, move the plane to and fro along the length - use a bit of wood as a fence for straight lines and it looks like it's been perfectly done by experts! In fact it has!
