Hi - I’ve got a SCM Mini max Lab30. The planer works fine but the thicknesser has stopped. the operating process is:
1. Rotate the selector switch to thicknesser
2. Engage the thicknesser lever
3. Press the start button
What then happens is a single click sound like a trip switch. Motor doesn’t engage just hums.
I have run the planer with the planer lever engaged and the feeder roller turns ok. When everything is turned off I can turn the feeder roller by hand.
The both use the same motor so I don’t know where to investigate next!
My advice welcome please…thank you.
