jimmer
a right member
Sgian, just to clarify, there is no pressure bar. there are only an in and an out-feed roller, and the cutter head. both rollers are sprung of course, but they do seem to be about 0.8mm below the blade circle ark, by the by.
otherwise, since everything apart from the head is adjustable, the answer to my original query would be to use the magnetic type setting jigs to set projection from the cutter head. this is now done, with the projection the same as it was before (correct or otherwise, but in the ball park) and with blade nice and square, having got the outfeed table properly square off the head, and then the blades square from the outfeed table, as i described in a previous post. to be clear, i didn't use the outfeed to set projection, this i did off the thicknesser bed from the setting of the previous blades, i then used the outfeed to square them up, tho they were pretty much spot on from the thicknesse bed, thankfully.
so those magnetic guides yes, but the rutlands type model which are pretty ubiquitous, are apparently for heads of 75mm dia and above, mine is a 60mm.
for the meantime i'm happy enough with the projection, and do not need the stick method to set outfeed, thanks
lastly blade width as you call it, tho height migh tbe more accurate, is irrelevant in this situation because they sit on little springs, rahter than a win-up/dwon mecanism.
