I use my router table as an edge jointer by offsetting the outfeed fence, but something is happening that I dont understand.
The fence is a brand new UJK professional (but this used to happen on my old home made fence as well). I pad the outfeed fence with 2 pieces of flexible plastic that are 0.8mm thick. These were cut from the same sheet and I have measured them and swapped them around with no difference found.
When setting up I usually align the out feed fence with the cutter blade to start. If there is snipe on the end of the wood I adjust the infeed fence untill the snipe disappears. the result is a very good surface.
BUT...........
The finished cut takes off more one end than the other.
Starting with a piece of wood that has two parallel sides, every pass reduces the back end measurement by 0.5 mm.
If I were to pass the wood across (for arguments sake) 4 times. the wood measurements change by 2 mm. I can reverse the wood and counteract the angle on smooth grained wood, but sometimes the grain will not allow me to feed from the other end.
Why is this happening?
BUT...........
