flintandsteel
I've an old Elektra Beckum planer / thicknesser which has served me well over the last few years.
Just recently it's started to misbehave, particularly noticeable when passing narrower sections through it.
Sometimes the planed surface comes out planed but with a wave like surface for want of a better description (high & low spots) and the section tends to migrate left to right as it passes through the machine. Mostly OK though with wider timbers.
I used to work mainly with Ash, Beech and Elm but I'm now using a lot more Oak.
I'm wondering if it's the Oak taking the edge off the blades quicker or even if one blade might be out of true.
Obviously I can check all the above and replace the blades but does any of the above sound symptomatic of another issue/s I haven't considered.
