Mr Ed
OK, here's one I've been mulling over for a while, but the recent thread on flattening LN (or other) planes brought it to the forefront of my mind. Not the bit about flattening, but the discussion of the phrase 'super smoother' and whatever that may mean.
We all know that a longer plane can create a truer surface as the length allows it to bridge the bumps and plane a level face. Hence the reason a jointer is the length it is.
We also know that generally heavier smoothing planes are thought to be better as the weight gives momentum and stability on the work.
So, given those two facts, why are smoothing planes generally fairly short? Surely a longer, heavier plane would be a good thing provided the weight is not so great as to be tiring. I have heard David Charlesworth quote that Alan Peters did everything with a No.6 and said the work would have to be very small before he would consider using anything shorter. I presume this is where David C's phrase 'super smoother' begins to come in.
So why having made the work true using a longer plane (or a machine surface planer) would you want to finish it with a short plane, other than if you wanted something easier to handle? Assuming that is the case, if one feels comfortable with handling a 5 or 5.5 for finishing jobs why would you need to own a shorter smoothing plane? (This is genuinely a question not a statement phrased as a question - I'm not sure I know the answer...)
Any thoughts anyone?
Cheers, Ed
Cheers, Ed
