Hi Lurcher,
I did exactly the same as you, wee while ago.
All the advice on the forum was really helpful and much appreciated, however......
I found that I had to invest a considerable amount of time on the "extended yokes", regarding the taper thickness and to remove the sand marks, thus improving the. Smooth adjustment. I did do a series of photos with the intention of posting on here, but was to desperate to make a mountain of shavings.
I was also concerned that the brass would block up my ezelap diamond plates, so you may want to buy a few grades of some abrasive sheets and I believe chalk used on a file will prevent it getting blocked up, sorry can't remember the correct terminology.
I was working on three brands and five sizes of planes and multiple blade/iron combos, Matthew ( thanks again) did tell me that the yoke pin was slightly tapered, can't remember which brand/vintage exactly tho.
Mike....if you were the gent ( i'll look through old PM's) who posted me the no 8 cap iron, I just won the hock combo last week, I'll get it in the post to you, when I'm back from Taiwan, just before next term begins.
