George,
Take comfort; the first thing most folk do is toss the Stanley blade and get a better one anyway. I'd suggest cutting to the chase and doing that first, rather than wasting a lot of effort on the blued blade. Depending on how bad it is, you could possibly carefully, and slowly, and above all cooly, grind past the area that's lost its temper, I suppose...
Grinding a primary bevel on a high speed grinder is not the impossible task some would have you believe. Here, have a bit of a brain dump on it:
1. Is the blade edge in reasonably good shape? That is square to the sides of the blade and so forth? If not, adjust the rest so you're grinding the edge at 90° to the back and get it the right shape
first.
2. The coarser the wheel, the better. It'll grind quicker and thus cooler. You don't need a fine finish anyway, 'cos this is just for removing a lot of metal in a hurry, not getting a sharp edge.
3. Keep it dressed regularly. A clogged wheel will grind slower and thus hotter.
4. Don't press the blade into the wheel like you're trying to squeeze your holiday packing into a match box. A gentle touch on the wheel is all you need; the wheel will do the work.
5. Keep a finger on the back of the blade not too far from the edge; if it starts to feel warm, stop grinding and let it cool down. Some folks say you should never use water to cool the blade 'cos it'll create minute cracks, but I dunno, it shouldn't get that hot anyway should it?
6. Don't grind right up to the edge when you're forming the bevel angle. I forget the recommended distance to stop at; I probably stop grinding about a mm or two shy of the edge. The thinner the steel, the quicker it'll heat up, see?
Most of that repeated plus a couple of pics
here if that helps. Just take you time and it should be just fine. Try it on the ruined blade and you'll have nothing to lose anyway.
Oh and £1.24?! You sucketh most mightily. :lol:
Cheers, Alf
