Hi, I'm a newbie to the forum. My principle experience in woodworking has come from what I've learnt renovating a large timber frame farm slowly over the last 10 yrs. Typically tasks include limited oak frame construction and simple furniture items such as radiator covers. I've struggled with a haphazard workshop for years, but having nearly completed my garage and workshop, I'm looking to spend a little money to buy the tools that I know from experience are going to assist me.
My current dilemma is concerns drilling peg holes for oak framing. Typical timbers I work with may be upto 100mm width and 80mm deep, and peg holes are typically 19-20mm. I've drilled peg holes in the past free hand with a hired high torque drill - my corded couldn't handle the torque, but in hindsight they may have been due to using an auger bit and the high feed rate that implies. As you can imagine, the holes have been less than perfect and very time consuming.
I'm considering moving to either a drill press or drill stand and a high torque drill, but need to think through the following
Any comments or advice would be welcome
- - Do I really need the high torque to drill 20mm dia 80mm holes, or was that incorrect drill/feed speed choice?
- If I do need that kind of torque, I guess it takes me into the large end of pillar drills - many posts seem to suggest a secondhand drill might be more cost effective here. Drill plus stand wise, I can see a top end Makita that will provide the torque and fit a stand.
- Can I get the throat/quill length that I need from a stand - even the top end ones don't seem to offer quill lengths above 70mm. Some of the bigger drill presses seem to offer this
