Graham Orm
I've had Blackberrys' for my last 2. Fancying a change, needs to be pocket size.
Zeddedhed":wf6pkw3p said:iPhone.
I've had one since they came out and am now so utterly wedded to the apple ecosystem that I couldn't easily change. Not that I'd want to. Ever.
custard":1x6nwmy0 said:I went from a Blackberry to an iPhone, discovered internet Sudoko, and life's never been the same since!
Wildman":23x8ek6e said:2 empty tin cans an a length of string :roll: :roll:
Wildman":7gtwfiaf said:2 empty tin cans an a length of string :roll: :roll:
Too bigSelwyn":35gx2cc6 said:Look at going sim only for about £10 month. An LG g4 is a good phone as is the cheaper g3 or theblite version of the g4. See ebuyer
morfa":139zw22s said:Graham - Whats the current model of BlackBerry that you're using? What's your budget. If I know the size and budget, I can give you some options.
However more generally I went sim-only recently and bought a 'cheap' Android phone. Saved a bundle and it does everything I need.
petermillard":2qfn2e6w said:Might it be worth pointing out that pretty much any touchscreen phone will 'feel' bigger than a classic Blackberry, just because it's all screen, and you're just not used to it? Also, if you dig into the specs you'll see that e.g. the current iPhone 6s is only slightly taller (1/4" or so) than a Blackberry Classic, but is also narrower, thinner and lighter.
Cheers, Pete
