cornucopia":qkmwgqzx said:spindle work is between centres eg chair legs, stair spindles, tool handles etc
wabbitpoo":3t3837rf said:What does the deeper flute on a bowl gouge do for you? ......
Mark Hancock":1yf72xps said:cornucopia":1yf72xps said:spindle work is between centres eg chair legs, stair spindles, tool handles etc
A better description is parallel grain turning - the grain runs parallel to the headstock spindle. "Between centres" can apply to both parallel grain and cross grain turning.
All of my turnings are started between centres regardless of grain direction. The only limitation is the swing of the lathe.
cornucopia":384pqm1q said:Mark Hancock":384pqm1q said:cornucopia":384pqm1q said:spindle work is between centres eg chair legs, stair spindles, tool handles etc
hmmm kind off- but then that would make my vase's spindle turning which there not :-k
wabbitpoo":2quprnwi said:What does the deeper flute on a bowl gouge do for you? And where would you use a square grind or a fingernail grind on a bowl gouge?
