scooby
I haven't made a pen since I started turning last year, so thought it was about time. Its just a cheap kit from Axminster, the blank is called "festive maxi' (I think). The reviews slate it for exploding if you use a barrel trimmer, I used the sanding disc on my lathe.
I'm not overly happy with the shape, I don't have a mandrel at the moment so I turned the blanks separately using tbc drives. So the 2 halves aren't a great match.
Finished with about 4-5 coats of Chestnut melamine lacquer and a buff with carnauba.
edit: just noticed I need to press the clip end down a bit more.
