Steve Blackdog
This is probably about wood rather than decorating, but if anyone knows about exterior decorating, I could do with some advice.
Some years ago we had a very old exposed exterior door stripped (by cold dipping). It was cleaned up, thoroughly washed off and danish oiled (not by me!). It is one of those old studded doors, with oak studs, and so a real pain to decorate.
After about a year we noticed that the danish oil had gone sticky and in a number of places it was completely washed off by the weather. We couldn't just top up the danish oil as it had a stain in it and so started to look a bit like a tiger pattern.
So I wire-wooled the whole door clean, went over it with white spirit, made sure it was dried out then sealed it with Sikkens instead, which is spirit based. I was pleased as punch - it looked great.
After about six months the Sikkens started to bubble, exactly where the danish oil had gone before. I rubbed it down and touched it up again. A few months later - same again. To put this into context, you could wipe it with a soapy cloth and large patches would wipe off on the cloth.
Fast forward to last year, I stripped the door again, with Nitromors and washed it off. I decided to rehang the door and leave it unfinished for a couple of months to let it properly dry out. In the areas that the finish would not adhere properly, the underlying timber has become very slippery and slightly spongey. When it was fully dried out, it seemed to be fine.
During a dry spot last summer, I prepped, painted the problem areas with wood hardener, and primed the wood and then glossed it. It looked great.
Now the undercoat and top coat have lifted at the problem areas - the paint has a skin on it you can push off with your finger, exposing bare wood. Where this has happened, there are spots of black mould.
I have concluded that the original danish oil was probably applied before the door had fully dried out. I suspect that the wood (pine) has started to rot, such that it cannot be fully dried. Or at least it is 'infected' with some kind of fungus.
I can't cut out the offending wood. I want to be able to do something to it to make paint stick to it.
All advice gratefully received.
Steve
Steve
