Hi
I have been looking at different jointing methods and have got some good advice and info regarding the Domino from people on these forums. I use a Dowelmax which produces good strong dowel joints but want something with less hassle for bigger jobs, for example my last cabinet used 132 dowels that required 264 holes. Looking at this peanut it is only suitable for sheet goods, it would not have helped me wheras a domino would have and can also handle the sheet goods. I am not a Festool fan and not loyal to any brand, best quality / suitable tool for the job attitude and my biggest issue with the domino is no competitive machines so no choice. Peter says there is a void between biscuit joiners and Lamellos/dominos but I think they are aimed at different markets. This peanut system cannot be classed as being used to produce high end cabinetry, the end result is a flat pack product wheras the domino and others can deliver a pre assembled cabinet. When I think of flat pack units, the bit that fails is that screw in pin that engages with the cam lock, it breaks out very easily and a flat pack kitchen only gets its strength from good installation and neighbouring units. If you want something to assemble later then I think the domino connectors certainly look stronger and better quality, ok they are £1 each but compared to that plastic peanut pin at thirteen pence, there is no comparison. The best thing about the peanut system in my opinion is the actual jig, that looks top quality and probably warrants it's £400 cost and that drill stop collar looks substantial. To conclude, from my perspective at the moment the Domino is the front runner, just line up and push, no clamping work down, no MFT workbench, no collection of parts to swap and change and a wider range of joints can be made.
