Rob Cheetham
I have access to a couple of unwanted IKEA wardrobes that I was thinking about sizing down to use as pattress boards. It's the usual chipboard with parts ranging from 15 to 20mm thick.
I know the standard is to use ply or osb but would there be any problem using these or would they be too prone to moisture in the long run.
My walls from outside go
Cladding
Counter battens for air gap
Kingspan breather membrane
100mm rockwool
Vapour barrier
Then will be installing 11mm osb boarding
Any help would be great. Cheers
Cladding
100mm rockwool
Vapour barrier
