Actually, not just any paring chisels. I could do these in O1, and probably 52100, and commercially treated steel like A2 would be almost nothing due to its stability (or XHP/V11 if I bought a knife blank in 0.25" fare, though I'm not sure if it would forge weld - maybe not, but on a parer, forge welding the bolster wouldn't matter).
My *hero* of making things, if there is such a thing, asked if I'd make him a set of parers. I don't want to make him just anything, so I'm attempting to make them out of 26c3, which is ever so slightly different than white 1 (it has enough manganese and chromium in it - just a little - to harden in a fast quench oil -meaning it can be made into solid tools with some cross section. But it's far faster transitioning - or needs to cool much faster than O1 to get full hardness).
When it does, it's like a japanese chisel in solid form. Extremely crisp, the wire edge goes away on a middle stone and it has great edge strength....
....but OOOOOHHH the warp.
The two in the background, I"m keeping for me. The two in the foreground (there will be five total) will be for George - the only person who ever said "you know, you did OK, but if you did ____ instead on the next one, it would look much better". Of all of the makers I've ever known personally, none are remotely close to George. I won't ever make anything as good as anything George made, but the fact that I can make "ok nice things" is attributed to his sort of laying the obligation on me that even if I'm going to make things here or there, I could do them in a way that they're nice.
These taper from just under 0.25" thick to 0.11 at the tip, and the taper is curved on the top just so nobody with good eyes ever thinks they're common (the maker's mark is on the other side). The are probably about 63/64 hardness where I have them tempered without the brittleness that most lower carbon steels come with if you try to push them to that. The hardness allows them to take a super crisp edge (close to the buffer edge) off of a common washita stone, and they just cut so/so on a fine india, even though they don't have anything in them that's abrasion resistant other than iron carbides. The trace amount of chromium is used up to make the iron carbides harder and help the steel harden better without having to be quenched in brine.
In order to have something resembling straight, they have to start fat and be ground....how fat that is....an hour of grinding on a ceramic belt freehand after hardening to get them to final shape. So as not to burn them, I handle them with bare hands and apply pressure with my bare fingertips and the backs of my fingers. Ceramic belts are kind of a wonder product if you can supply the speed they need to work right (like 2500fpm plus with the ability to apply pressure at that) - when they're fresh, you can do this without burning your hands and without going too slowly.
The one top left is near finished, just a little bit more hand finishing to go. The one bottom left needs hand finishing to clean up some of the lines, but I'll get that done. The last three will be a bear. Not sure if I'm going to make a full set for myself, but no sane person would ever make these for sale.
There is a lot that goes into these that has nothing to do with grinding or making a certain shape - in order to get the steel grain to be extremely fine. I think they are about as good as any parer that I've ever used, and better than the average by quite a bit. If I just used something like 1095 steel or O1, they would still be good, but the level of satisfaction when making them and then using them and comparing them to older chisels wouldn't be quite as high. There's no new western parer that comes remotely close. That sounds a bit pompous, but I'm more than familiar with making mediocre tools, and after making two hours of dust just rough shaping these the last couple of days, I'm willing to stick my neck out based on what it's taken to learn to do everything from forge thermal cycling to hardening and tempering and shaping to end up with a paring chisel that is pure sex to use, and not the least bit dainty feeling, nor clunky.
