Paring Chisel ?
DaveL
19 Oct 2002
Sudbury, Suffolk
While trying out the new wet grinder that I got from B&Q, I looked though a pile of old tools for an old chisel to test the grinder with. :oops:
Well this is one of the finds that was lurking at the bottom of the heap.
Would this be classed as a paring chisel? It has a stamp on the blade.
Which means nothing to me, but then what do I know!
The chisel ground well and has taken a very keen edge, bald spot on arm is now stubbly :roll:
Dave,
It is a bit short for a paring chisel - although it could of course have been ground down considerably over its life. It is a firmer chisel (square sides) probably of good steel, although I don't know of that particular make (there were hundreds of Sheffield makers at one time) .
There is no reason you couldn't use it for paring and the angle at which the handle is set suggests it was used for this - although the tang may simply be bent.
Dave,
I agree with Chris, it's a firmer; it's a bit beefy for a paring chisel, even a shortened one. F(rancis) G(eorge) Pearson & Co operated between 1856 and 1957 and "Acute" was their trademark. I expect it's good quality cast steel, and I bet it'll be a lovely user. :D
Cheers, Alf
