strat
Hi. I had dimensional plans for turning fprmers to make seed pots from newspaper. Unfortunately I have lost the plans. Does anybody have a copy of the plans or website where I can source them from please? Many thanks.
Although tearing it with a rule is what I would do. Much neater. I was just reminded of something I learned many years ago. If you try tearing a newspaper freehand and in a straight line but the tear doesn't follow a straight line, turn the page over and try again. It should be straighter. We have not had newspapers for many years so I don't know if it still works with modern production papers.Tear up your newspaper using a steel rule. Scissors are a pain.
Indeed. All paper has a "grain". I rather think that, instead of "turn the page over and try again", that might read better, "turn the page around and try again". It will tear better along the grain than across it.Although tearing it with a rule is what I would do. Much neater. I was just reminded of something I learned many years ago. If you try tearing a newspaper freehand and in a straight line but the tear doesn't follow a straight line, turn the page over and try again. It should be straighter. We have not had newspapers for many years so I don't know if it still works with modern production papers.
Gary
That's it. I remembered it wrong. I knew about the arrow and the printer paper too.turn the page around and try again
Base 3" wide, central boss 1 1/4", outer ring 2 1/4", ring is 3/8ths deep.
Former is 2" dia, hole is 1 1/2" wide, 1/4" deep. Cylinder is 3" long but I should have made it 4 as I use the pots for sweet peas and they like a long root run.
Hth
