Allubo
This was a relatively easy project and I'm afraid there aren't that many pictures. My parents have just redone their kitchen and wanted something a bit different for the table.
The top sits on units underneath for storage so the project was just a 36mm top lipped and then veneered.
It's a 36mm mdf core with walnut lippings and veneered in paldao. It wasn't a cheap veneer and arrived pretty beat up so needed a fair bit of tlc before joining.
Normally I would hand plane the lippings but because of the way they were bent around the curve, it made it awkward at the ends and breakage was terrible. I came up with the idea of making a base for the router which allowed me to use it as a lipping trimmer with a straight cutter. It was just offset Sao much that it was balanced on the table and not hanging over the edge.
Again when veneering I cut a sheet of hardboard to match and covered in parcel tape to stop it sticking.
It was sprayed in 40% sheen PU lacquer and finished with beeswax.
The concept was very straight forward however, the lipping kept springing off at the ends because the radius becomes so tight. I ended up running a biscuiter on its deepest setting though the centre of the lipping then sticking a walnut tenon in and planing it off to hold it into the mdf. It worked great and was undetectable once flushed.
Sorry there aren't more pictures.
Alex
Alex
