wobblycogs
My P/T (Jet JPT 260) has just broken down and I thought I'd let everyone know how so that hopefully you can avoid what I'm sure will turn out to be a very costly mistake.
I was starting thicknessing up a bit of oak. I measured one end at 24mm, set the table to a 23.5mm and started feeding the piece in. I was greeted by the P/T's usual happy wood munching sounds right up to the point where the wood stopped moving. I immediately spotted the problem, hit the power button and lowered the table to recover my now slightly mangled piece of wood.
I'm sure all you seasoned veterans have spotted my mistake already - the wood got thicker towards the bottom end and had jammed against the kick back fingers.
So what broke I hear you ask? There is a large white plastic (yes, plastic) sprocket that makes up part of the drive train for the feed rollers. About a down teeth on that sprocket have sheared off. Oddly enough it didn't fail straight away I was able to put about 20m more wood through before I noticed any problem.
What I assume happened was when the wood jammed the feed rollers kept going and sufficient force was placed on the plastic sprocket to deform the teeth. Then, a little while later, they just gave up. To be honest I'm really surprised the belt didn't slip as it's fairly loose but looks like the sprocket lost the battle.
Will be looking up replacement parts in the morning, might need an engineer though as it looks tricky to replace.
