Hi All,
I'm replacing a table top (previously a ceramic mosaic which the winter killed) and have chosen to use Siberian larch planks. Unfortunately, the planks are only available around here in 3m lengths and the table is 1.57m long so, to avoid wastage, I'm planning to put a breadboard at the ends so that I can then get 2 lengths out of each plank.
My question is, how should I joint the planks to the breadboards? Also, should I do anything else to help keep the tabletop in shape? I was thinking about using half lap joints. I don't have a table saw, just a circular, jigsaw and compound mitre and nothing esoteric like biscuit jointers etc. I'm aware that the planks will expand and contract across their width whereas the breadboard length won't change so unsure about how to keep it all flat in the beautiful Stockport climate...
The table frame is a metalwork grid with a lip around the edges so I'm planning to just rest the top in there rather than fix to the base. The planks are 143mm wide, there will be 6 of them with approx 6mm gap between each.
Hope that makes sense! Any advice gratefully received.
