Heyho2022
New member
Hi Guys,
Sorry if this is a daft question...
Can outdoor planters be made out of OSB sheets?
The idea is that the OSB sheets would be used to form a rectangle ( painted with outdoors / weatherproof pain ), then some pattern layer / slats over it out of pine?
The planter itself would be raised slightly off the ground, but as mentioned - it would spend it's life outdoors fully exposed to the elements.
The reason I am considering OSB is purely down to the savings vs other materials.
