woodbloke
I've just completed this floor standing Japanese lamp in English Oak with ebony detailing on the feet:
...and in it's spot in the lounge it looks thus:
I can't take any pics of the lamp lit up, as they come out all dark In order to have the minimum amount of shadows cast by the lamps, the innards are made out of 6mm acrylic plastic, suitably bent and shaped:
The top part of the lamp contains the handle, which consists of a pair of cross rails:
m/t into the sides, with the handle halved and doweled in place. The shoji panels were made from 12mm stuff bridle jointed at the corners, with the centre sections m/t'd in place with 10x3mm tenons. Applying the mulberry paper was a breeze and much easier than I expected and each of the screens is stuck in place in the rebates with a few blobs of Blu-tack. This means that they're relatively easy to remove if one of the screens gets damaged and needs to be replaced. Finish is a couple of coats of matt Osmo-PolyX with Alna teak wax over the top. As the lamps were wired in parallel, the little box on the bottom rail (fixed there with a strip of d/s tape) contains a little bit of terminal block for the cabling
Comments as ever muchly appreciated - Rob
