CNC Paul
This is for Mike Garnham our resident construction meister. 8)
I do rent a workshop but I would like to add to my workshop at home, the existing structure is in 225mm Solar blocks. My plan is to manufacture the addition in modules 600mm wide by 150mm thick by what ever height fits in with planning regs, they would be constructed in 18mm structural plywood cut on a CNC router and assembled with annular ring nails then filled with something like Warmcell. The exterior would be covered in Housewrap with 20mm vertical battens and then then finished with feather edge Larch or similar.
I hope you don't mind me asking.
My questions are? Is the method of constructon viable, do I need any additional vapour barrier and how would I determine the load bearing capabilities of the modules.
