rafezetter":244h4y16 said:Great job - I'm always amazed at how the wood comes to life when finish is added, as raw that wood didn't look like very much...
What is that black magic cleaner you used? Is there an equivalent over here anyone know? (or is it just autosol..)
rafezetter":12jpabc1 said:What is that black magic cleaner you used?
bugbear":xydjy71x said:rafezetter":xydjy71x said:What is that black magic cleaner you used?
Google says:
http://www.amazon.com/Kleen-Bore-Black- ... B0000C51WN
BugBear
swagman":2uxh282h said:
Berncarpenter":1emykm5q said:Wow Stewie great job ,whats left from the original saw just the folded spline ?
Cheers Bern
swagman":1jhusln1 said:Berncarpenter":1jhusln1 said:Wow Stewie great job ,whats left from the original saw just the folded spline ?
Cheers Bern
Folded spine and saw plate are original. Original handle was cactus.
Berncarpenter":2kzjz2xk said:swagman":2kzjz2xk said:Berncarpenter":2kzjz2xk said:Wow Stewie great job ,whats left from the original saw just the folded spline ?
Cheers Bern
So that must have been a bit tricky ,how did you remove the saw plate from the spline without any damage? Cant see the original handle holes in the plate ,did you cut it down in the length ?
Cheers Bern
The Bear":3clgzpr5 said:Great job
Any secret to cutting the saw plate and cleaning it up?
Mark
