Old Bandsaw Blade Uses.
It was a serious question - anybody?
if You have one, an angle grinder, or notch with the edge of a grinder wheel and then snap off in a vice. Then, if you do have a powered grinder, you can shape the ends etc. Wear protective gear.
If you're completely manual, notch with a diamond file or coarse plate, snap in vice and again, shape with the plate.
You may find a regular file works ok if blade not too hard.
When drilling or the above, if the blade overheats it may soften, but also could harden, so become harder as you work - depends how hot it got and how quickly it cooled. For holes, I managed with hss or carbide drills, but spoiled some and a chance find screw hole punch was much better.
I made a frame saw from a broken blade. Don’t really need it but enjoyed making it.
    160.3 KB
Cheers. Noted.
Cut the blade but leave it full length. Fit a T handle to each end. Dig a pit. Roll a tree trunk over the pit and send one of your family down below. Stand astride the tree trunk, lower one end of the blade into the pit. Then the 2 of you make planks.
Or not.
sure I read somewhere that this was the origin of the terms top dog and under dog. Under dog being the one who has sawdust falling on their head !
In my case I just bent it backwards and forwards between 2 pairs of pliers. I hasten to add that it was the blade that came with the original band saw buy, and NOT the Tuffsaws blades I have now!
But an angle grinder would also work of course.
The spring steel is good for shaw guards. No one seems to sell these, but any spindle HSE drawing always shows them. Work well with router table too. The spring steel can be drilled when locally softened. This is best done in a drill press by attempting to drill where required with a suitably sized nail. This will make a red hot drill sized spot, which will soften on cooling.
--The spring steel can be drilled when locally softened. This is best done in a drill press by attempting to drill where required with a suitably sized nail. This will make a red hot drill sized spot, which will soften on cooling.
By gum that's clever. Thanks.
geoff
geoff
I have just been rehandling a hand saw, and while my special punch (originally designed for ???) works fine, the holes I needed are too far from the edge - I understand and tried the nail trick but can't seem to get it to work - I can drill with an arrow point carbide (careful, go very slowly) but couldn't find mine so tried a 'cobalt' drill, not much help, back to a cheapo hss bit, which broke. Being a cheapskate, I keep a little box of broken bits, to regrind, one day that never comes. In frustration I tried the broken off bit -- bingo - it worked, as did another. They're stiffer, being short, and the rough edge seems to bite fairly quickly, just make sure no part of the broken end is sticking out too much. I do use a pointed punch hit quite hard to mark the place and give a small dent. This is def not a technique for accurately sized holes, but my saw is now well re handled with 5 brass screws/sawnuts. Started at about half diameter bit and then on to full, the rough edge of the hole actually helps to grip the wood - it was pretty firm without any screws.
It is very easy to forget just how thin, and flexible, the web in the middle of a twist drill is. Especially on drills of 6mm or less. I must remember to save broken bits, although the day they get reground is likely to be the day after yours. Hey, hey.
geoff
