Mooeee
Here are some off cut pieces of wood:
Douglas Fir, the longest piece is 475mm X 190, most of the others are between 300mm and 390mm and approx 120mm wide, all are about 25mm thick 11 pieces in total.
European Walnut, not much but thought I would throw them in, 3 pieces which might make somebody a bit of veneer, Longest piece 800mm X 175mm about 6mm thick and the other two pieces you get an idea of what's there.
Not sure what this wood is, it looks as though it's spalted and might make some nice pen blanks, Longest piece is 550mm X 190mm, so should give you an idea as to what the other mixed sizes are, 11 Pieces in total and vary in thickness some 40mm, some 30mm and some around 25mm thick.
Another piece of what looks like a piece off a window cill frame.
Again this must be collected from the Stevenage area about a mile and a half off of junction 6 of the A1M
FTAGH
FTAGH
