Hi
New to the group. I have started an oak gazebo project. I am using 6 inch posts and beams.
One post will have an oak brace on either side of it (braces in the same plane). Therefore the tenons of each brace will be at the same level and the mortices both central on either side of the post. With a mortice depth of 70mm to allow clearance for the tenons (circa 68mm tall) there will only be about 10mm of oak at best between each mortice. The motices are 1.5 inches wide.
My query is whether this will weaken the post significantly? I assume not as I see plenty of post/braces with this configuration on the web
Regards
Jon
Regards
Jon
