Dusty
Here is a "little" job I have just completed , took me the best part of a week . The main trusses are made from semi air dried oak and the main columns are from green as green could be . The reason for the semi dried was to reduce the shrinkage in elements that wont be affected by the weather , ie under cover . The whole frame is fitted together with moritce and tennon and pegged including where the trusses connect with the main side frames . This was made from working drawings supplied my the main contractor and fitted by a third party . The only part missing is the finial which will be fitted at final height once the roofers have been and worked their magic . The first few pics show a dry fitting after production prior to delivery to site . What you can also see in the dry fit is some dummy pieces fitted at the ridge point to allow for fitting of said ridge once the frames were up . The whole lot was given a final sanding once the dry fit was completed .
Corbels being offered up , fitted with loose tongue on site .
Fitted on site
Thanks for looking
Fitted on site
Thanks for looking
