To give a little more detail, I'm planning on replacing the roof and one long edge and one short edge wall. The other 2 are already there and are brick.
It's a nearly flat lean to. 4.5m long by 2.5 wide. The current design windows are 2m high and 1m wide. I'm replacing rotted softwood which was about to fall on our heads, with kiln dried oak and c16 roof framing. The roof would be ply and onduline bitumous corrugation.
Thanks for the advice so far re: top plates and headers. Plenty to think on.
This is an early design. I'm looking at having the roof over hang but haven't decided exactly how to do that or worked out loads. Especially that side over hang on the plates which I realise might not be sufficient as is.
There are 1x2 and 1x1 oak windows stops going in. The glazing will sit inside the posts/plates but not rebated into it as the stops will hold them.
The solid areas are existing brick walls. Not all noggins etc are shown.
