So this has been a long time coming but since this project is finally coming to an end I thought I would get started with this WIP.
Our first baby arrived in May this year and despite being a relative amateur to woodworking I thought it would be nice to make a cot. Once the decision was made I set about finding a design that I liked, and I eventually came across a thread on here with a design by Simon Blakeney which was exactly what I was looking for. I used his design as the basis for mine, with some slight tweaks and the addition of a drawer in the bottom.
I took a delivery of Euro oak from British Hardwoods, their calibrated boards are 24mm x 200mm and relatively cost effective. I definitely needed a thicknesser as many pieces are only 10mm thick, with the frame being 20mm.
I set my designs up and I was ready to go:
Firstly I needed to make a router table, and I then went on to make a box joint jig, which works brilliantly.
I then set about making the slats. There are 36 of them, each 10mm thick. I was very conscious to make these as accurately as I could since these would be going straight into a mortice. They were all cut to within 1/10th mm and rounded over on the router table.
After a few test cuts of the mortices I finally got a perfect fit
I made a simple mortice jig which was very effective
Test fit
Eventually I was able to start putting it all together, I have to admit there was some swearing but it all worked out in the end
Then the sides were put together, nicely square
And the other side
And finally putting it all together!
And after two coats of osmo oil
Now I'm just putting the finishing touches to the drawer so there'll be another update in the next week or so. Cheers!
Test fit
And the other side
