DougieH
Just finished a small oak bowl, about 4in by 2.5in. As I was shaping the bottom, a couple of cracks appeared. Was this bad technique on my part or were the cracks already in the wood? Its not a big deal for me as the bowl was turned to hold my loose change. I also included a photo of the bowl on the lathe. Its held with double sided sticky tape (the kind used for carpets). I turn the base to the same size as the faceplate I will use, then position the base on the tape, on the faceplate. I also used it on a 9in platter. It was fairly heavy cut I was taking out the bowl, and it never moved at all. Used a 3/8in bowl gouge, a 3/4in skew, and a 3/4in curved scraper on it. Because of the cracks, I brushed a load of Rustins Button Polish into them to try and seal them a bit, then polished with Black Bison wax. Hope this is of interest.
Doug
Doug
