Hello, I've seen a few different threads for the Nutool CH10 Pillar drill and thought rather than hijack one of those, I'd create a new post with all the information I've gathered.
The problem with all the videos and how to's is, nobody lists actual numbers and sizes, so you have to dismantle your drill and measure everything before waiting for parts to arrive, all whilst hoping you don't lose all the bits before you reassemble the thing.
So for future reference here are some of the common bits a Nutool CH10 requires.
2 x 12mm I.D. 32mm O.D. 10mm wide bearings for the spindle.
2 x 17mm I.D. 40mm O.D 12mm wide bearings for the pulley end.
1 x Z section V belt commonly referred to as Z27.5 (10 x 6 x 699 mm or 27.5 inches long in old money)
1 x (Jacobs Taper) JT33 Chuck, capacity is for you to decide.
This is a standard push fit.
I hope this helps anyone still lucky enough to own or able to buy one of these.
