A 3HP motor equates to a 2.2KW motor, a good amount of power for the task. With this motor, if your clogging up the blade you should be experiencing push back where the timber suddenly gets ejected back at you, which is slightly different to kick back where the back of the blade picks up the stuff and throws it at you. Anyway, that’s a bit of semantic. What should not be happening is your bogging down the blade. Have a look at the motor, I suspect strongly that’s it a single capacitor motor where the cap serves to both start and run the motor. When starting you won’t hear a discernible click when the centrifugal switch actuated. This type of motor is cheap, and not really suitable for a table saw, but often fitted to hit a price point. Fitting a more suitable blade will improve matters.
The other potential issue is that if it has a separate start and run capacitor, the run capacitor needs replacing.
