RossJarvis":10gwaxtl said:
Regardless of what use you're going to put the tool to I'm thinking that the sharper you can get it the better. The next thing to think about is how to use it and after that, how long will it stay sharp.
Hello Ross, your question about "how long will it stay sharp" is important and not frequently enough asked. In my experience a marking knife will stay sharp enough for several weeks use, a dovetail saw (assuming it's not a hardpoint) will easily last through a chest of drawers but may not make it past three chests of drawers without freshening up the teeth. A traditional Stanley or Record plane iron may give you about 10-15 minutes of constant use on oak (perhaps a bit longer for rough work across the grain), A2 irons will last about twice as long between sharpenings. If you're dovetailing then you can easily use a couple of chisels for rough chopping the tails and rough chopping the pins on one hardwood drawer, but you'd be advised to sharpen them before tackling the final paring cuts on the pins.
Just up the hill from you in Froxfield is a workshop with some pretty competent furniture makers. If you look at how they, or most professionals work, they don't try to get ultimate sharpness on any tool, but they do have a finely tuned instinct for the dividing line between "acceptably sharp" and "unacceptably blunt", and generally speaking they tend to adopt a little but often approach to sharpening to stay comfortably on the right side of that divide.
And for commercial working, even at the highest level, that makes good sense. You can waste an awful lot of time forming that bog roll slicing exquisite edge, but it will only stay exquisite for one or two strokes. However, allowing a tool to deteriorate to where you have to really force it through the timber is not only tiring, but it risks damaging a joint or a surface that you may have spent hours creating; so a policy of little but often, and without getting too obsessional about it all, is a sensible approach. That contrasts with the practices of many hobbyists I've known, who will take infinite pains using 15,000 grit waterstones or sub 1 micron scary sharp papers, but then continue using the tool way past the time when it needs freshening up.
