CHJ
T'was on a Monday morning that the Courier came to call.
Because I wanted the lightest head piece I opted for the 100 series.
This of course does have the limitation of being only TH2 compliant max. due to the crown and rear being open.
To improve on this I have embarked upon a trial using the associated fine dust environment cape which should put the assembly into the TH3 category as far as inward dust leackage.
Currently I'm going to use my old 3M turbo unit filter for air supply, did have some reservations as to whether the hose coupling would be compatible, but with the knowledge that an adaptor was an easy fix if necessary.
Turned out all is fine, Hood coupling is compatible.
Now need to save up the pennies for the latest lithium power/filter unit but as things stand not an urgent priority.
Not used in anger yet, but first impressions are that it feels comfortable when fitted.
Visor lift is good and stays put.
A little more care needed in fitting and removal if spectacles are not to be dislodged compared with old unit, this is mainly down to a better more flexible facial seal curtain and its elastic tensioning, something I'm sure will soon become second nature.
As far as the cape is concerned I think it will justify looking ridiculous to some folks just to turn a bit of wood, if only to shed all those annoying shavings that find their way around the neck, ears etc. not sure how robust and long lived it will be, being commercial I guess it's considered as one of the consumables, worst case scenario it can be used as a pattern to make some in house cloth versions.
For those interested in the specifics:-
http://www.thesafetysupplycompany.co.uk ... m-106.html
http://www.thesafetysupplycompany.co.uk ... m-928.html
http://www.thesafetysupplycompany.co.uk ... m-976.html
And the real piggy bank raider still to come.
http://www.thesafetysupplycompany.co.uk ... 315uk.html
